Hello!
Have you think about that you have line and there is reducer but line number is same... 😉
When you add reducer and set different size for both Pipe Line Segment and Line Number keep same. Then you take a look Pipe line Group list and then there appear "?" mark. Naturally of course Plant 3D don't know which size it should take a look.
BUT
1. Is there some way to set that Pipe Line Group take a look the biggest size of the line? Of do we just override and write it by manually?
2. How you have set this? Do you use Segment list or Group list when you will mahe Pipe List or do you use both?
3. I think only way to add properties to Pipe Line Group is via Data Manager?
Best regards
Matti
