I am new to AutoCAD Plant 3D. When starting a new P&ID drawing the default view is a white layout sheet with the project information boxes along the right side. How do I change this to the black model sheet?
That’s part of Autocad options still. I believe it’s the layout. https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoC....
Use the command TILEMODE and set it to 1 or 0 (zero) to switch between model and paperspace. or turn the showing of display layout and model tabs in options:
