AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Line Number not Coming in Isometric as per Model
6 REPLIES 6
kumarswapan64
365 Views, 6 Replies
In P&ID Line Number is Coming perfectly.
In Model also Line Number is coming perfectly.
But in iso Line number is not coming as per P&ID or Model. See Snapshot.
Please Help me, How to bring the Line Number in Isometric same as P&ID or Model.
Swapan Kumar
6 REPLIES 6
@kumarswapan64  Please see below link.
https://forums.autodesk.com/t5/autocad-plant-3d-forum/line-number-format-in-iso/td-p/3146180
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Sorry, It's not done.
The Line Number having 6 Components.
Can any one describe step by step to bring the Line Number (Service-Area-Number-Spec-Size-Insulation Type) in Isometric Extracted from Model.
Please help.
Swapan Kumar
Hi @kumarswapan64 ,
Try to follow the following step to reach the needed isometric output, as you indicated, some step are already done as well as P&ID setting:
* you need to edit isoconfig.XML  (for the iso output directory) to set the line number output format : refer to attached screenshot (001).
* ensure that the line in 3D Model are assigned by the full line number tag if not select the connected line and choose new tag from propreties palette then select add new tag: refer to screenshot (006)
* edit setting for iso style (for the same iso output directory) : refer to attached screenshot (002).
* extract iso using the edited iso directory. refer to screenshot (003-004-005)
i hope that's helpful.
sorry, if the attached images are not readable, refer to the following PDF File.
In Iso Style setup How to bring "Line Number Tag" .
Swapan Kumar
Choose "select Class Proprety"
Technology Administrators
AutoCAD Beta
