Need Nozzle THDF for equipement
abdelhalim_bousmaha
abdelhalim_bousmaha
Is it possible to add to the liste, as you can see in the screen shot, THDF.
If I choose PL, when I insert the valve with the end THDM Plant 3D put an Half Coupling.
I am working with A.P 3D 2021.
Thank you in advance.
h_eger
Dear @abdelhalim_bousmaha ,
these instructions should solve your problem.
https://knowledge.autodesk.com/support/autocad-plant-3d/learn-explore/caas/sfdcarticles/sfdcarticles...
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
abdelhalim_bousmaha
Thank you very much  @h_eger
