Modifying existing routing
rigginc
rigginc
Is there anyway to modify the length of an existing pipe run in 3D by entering the new overall length instead of entering the incremental increase (or decrease?)
Clint
with dynamic input on, scroll out so you can see the whole pipe....then when you hit the grip at the end, hit Tab key untill  the input option you require is highlighted then type in the value
