Latest Updates | New Knowledge Network Solutions | AutoCAD Plant 3D
matthew.d
matthew.d
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for AutoCAD Plant 3D?
 Subscribe to receive updates for new AutoCAD Plant 3D Knowledge Network articles.
For additional updated solutions, also check out the AutodeskHelp Blog!
2016 Solutions
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
matthew.d
December 2017
Is it possible to customize the properties which will be shown in the spec viewer?
Is it possible to adopt the orthographic bill of material (BOM) to categories only which are needed
How to delete columns in the dialog “Table Setup” for orthographic or isometric bill of materials (B...
Change in exported Spec data to Excel after update 2018.1.1
AutoCAD P&ID tags display as No Target
AutoCAD Plant 3D: How to get flow arrows to be the same color as the inserted line segment
Workflow for updated Inventor assemblies which are inserted as equipments in AutoCAD Plant 3D
Wrong enclosures for some annotations in isometric drawings
November 2017
AutoCAD P&ID: Drawing performance issue when using stretch command
AutoCAD Plant 3D 2016: Orthographic annotations will be moved automatically
AutoCAD Plant 3D: After placing a pipe the pipe disappears
AutoCAD Plant 3D: Gap when connecting pipe to UNION or COUPLING components
AutoCAD Plant 3D: How to Detach a Plant Project from Vault
AutoCAD Plant 3D: Is it possible to see the slope value of a pipe line in Navisworks
AutoCAD Plant 3D: Ortho annotation leader drawn through text
AutoCAD Plant 3D: Where are custom blocks saved for the catalogs
Background publishing in AutoCAD P&ID can cause PDFs and DWFs to have missing output
Can I move a catalog from a SQLite project in Plant 3D?
Converting a SQLite project via PnPProjectMaintenance.exe only works with Windows Authentification
How to add a smaller stub-in to an elbow connected at the top of the elbow
How to combine two different catalogs to one catalog
How to create an isometric drawing with British dimensions from a metric model?
How to customize the line number to match a client standard in AutoCAD Plant 3D
How to get an additional image from the model in 2D Wireframe into the title block of an isometric d...
How to remove duplicate tag information from AutoCAD Plant 3D
How to setup a sleeve as a branch in a pipeline?
How to show an insulation of an equipment in a P&ID drawing?
Is it possible to add only one bolt set for two flanges in an AutoFlange-joint/Flange-joint connecti...
Is it possible to compare the class definitions of two different projects by a tool, report, etc.?
Is it possible to configure an isometric table which shows all different kinds of connection types?
Is it possible to create a report for P&ID drawings of hand valves and control valves together in th...
Just-in-time (JIT) debugging error when creating orthographics in AutoCAD Plant 3D 2017
LTD-fields with date format won’t be shown in European format in the isometric drawing
Plant 3D : Unable to save report to Excel from report creator
Plant 3D 2018 : Fatal error while opening project drawings
Removing unused tags in AutoCAD P&ID / AutoCAD Plant 3D
Report Creator cannot be launched for one user
Setting of Shared Plant Content with A360 drive won’t be saved
Some components won’t be presented correctly after awhile
The “Assign Format” button is not visible anymore in the Block Editor of a tagging block
Unable to see existing pipe dimension in isometric drawing.
Which permission SQL Server permission is needed to create a SQL Server project
Wrong isometric presentation of stub ends after update 1 for 2017
October 2017
Are AutoCAD P&ID and Plant 3D backward compatible?
AutoCAD P&ID : Custom Valve Body for Instrument needs to be selected second time before it is visibl...
AutoCAD Plant 3D : Editing Same Spec using Multiple users in a project
AutoCAD Plant 3D: Bad display of several components
AutoCAD Plant 3D: How to change the thickness of a pipe line in the isometric drawing
AutoCAD Plant 3D: How to copy a pipe and keep the service information
AutoCAD Plant 3D: How to work parallel on a SQLite project in different networks
AutoCAD Plant 3D: Surface area of the pipeline
Dialog for _PlantInventorEquipmentConvert ingores system variable FILEDIA
How to bring Orthographic drawing into Piping Model in Plant 3D
How to copy an AutoCAD Plant 3D drawing to a new or existing AutoCAD Plant 3D project
How to download object enablers for Plant 3D 2018
How to edit tie in symbols so the properties are saved within the block
How to use 3D model layer for orthographic drawings with specific set line weights
How to use Inventor to create equipment for use in AutoCAD Plant 3D
Is it possible to assign different sizes to the pipelines on both sites if they are split by a contr...
Plant 3D : Drawing file location changed in Project Manager
Plant 3D : How to create a reinforcing pad in branch table
Plant 3D : Unable to open Catalog builder application
Plant 3D : Unable to see dimension preview while moving objects
Plant 3D 2017 : End type in Cut Piece List display incorrectly for pipeline with FW & FFW added manu...
Plant 3D: Annotations out of date when opening drawing
When running isometrics in AutoCAD Plant 3D the Spec attribute is blank
When using PLANTCUSTOMPARTS two error messages appear and afterwards the dialog is empty
How to remove the annotation for elbows in an isometric drawing
AutoCAD Plant 3D: Only some rows of the LDT-Excel-sheet will be listed in LTD-preview
Is it possible to create a pipe with an extrusion?
Plant 3D : Open/Check Out Issue on Vault project
Plant 3D : Vaulted Project shows Error Method Not Found
Randomly the nozzle dialog won’t be shown when trying to add a nozzle
AutoCAD Plant 3D: How to prevent small bore pipe from being drawn in the isometric drawing
Custom spec properties are getting shorter in the project
Cut length of fixed pipes won’t be shown in bill of material (BOM) in the isometric drawing
Plant 3D : How to route lengthy curved pipe
Tool Palettes missing in AutoCAD Plant 3D
September 2017
AutoCAD Plant 3D Report Creator export to PDF missing Chinese characters
AutoCAD Plant 3D: Copy Isometric folder configuration to a different project
AutoCAD Plant 3D: Equipment support legs foot plate is not rotated in-line with leg angle
AutoCAD Plant 3D: Files are being listed as read only in collaboration project
AutoCAD Plant 3D: SW COUPLING - How are the part dimensions calculated?
AutoCAD Plant 3D: Use a compound joint with fixed length pipe
AutoCAD Plant 3D: What is an isometric overflow drawing
How to adopt the height of the annotation square in the isometric drawing?
How to avoid spec breaking annotations in an isometric drawing?
How to change the name of the field weld in an isometric drawing?
How to get an overall dimension without anchoring at tees?
How to remove the “Cont’d From”-annotation from an isometric drawing
Off Page connectors do not work or will not connect in AutoCAD Plant 3D and P&ID
Plant 3D 2018 : Incorrect values in ASME Catalog Hex Head Bushing
Which files may be affected if the bill of material (BOM) for isometric drawings is changed?
AutoCAD Plant 3D 2015 - FATAL ERROR UNHANDELED e04343524exception at fb76a06dh
AutoCAD Plant 3D: Advanced option on Iso dialog box does not work
AutoCAD Plant 3D: PVC from Xref not connecting to equipment
AutoCAD Plant 3D: Show Insulation for valves and flanges
Floor symbol inserts multiple insulation annotations in AutoCAD Plant 3D isometric drawings
How to remove the centerline symbol for elevation annotations in isometric drawings
How to suppress the Small Bore Piping-theme in an isometric drawing
If you edit a spec using “Edit Spec” the spec won’t be correctly checked in in Vault
Is it possible to batch change the block name in P&ID from Chinese to English
Is it possible to modify the custom category and properties name in drawing properties
Where to set the needed anchor points for dimensions in an isometric drawing
Why Edit button is gray out for some properties in P&ID Class Definitions
Why the locating dimension won’t be shown till the end
How to rename the P&ID end connection?
Is it possible to set automatically the scale of an isometric sheet in the title block?
Some flanges won’t be offered for substitution for a Wafer-Flange-Connection
How to add additional symbols that can be inserted from the Create Iso Message dialog
How to configure a locating dimension from a flange-pipe-weld to the end of the flange
AutoCAD P&ID: This tool is not supported in a non PNID drawing file.
AutoCAD Plant 3D: Default actuators are not sized as expected for all valve sizes
AutoCAD Plant 3D: For the same project some users have only access to the AutoCAD P&ID part in the p...
AutoCAD Plant 3D: Unable to connect WF-valve to flange
A copied drawing from a different project will remember to the old tag format if a size will be chan...
Annotations in your drawing are out of date and need to be updated
A pipe cannot connect at the second port of a cap
Is it possible to hatch a section of an AutoCAD 3D solid in an orthographic drawing?
Is it possible to work on the same project with different installed AutoCAD Plant 3D versions?
Plant 3D : Data export to CSV not exporting correct format from Data Manager
AutoCAD Plant 3D: Lag in Large Files.
AutoCAD Plant 3D: Components with the same item code are placed in row on the isometric BOM
AutoCAD Plant 3D: How to automatically show the flow direction of an isometric drawing
AutoCAD Plant 3D: Show pipe QTY in isometric BOM shown in mm not meters
August 2017
How to show a custom status in an isometric drawing?
How to show a flanged pipe in an isometric drawing
AutoCAD Plant 3D: How to create flexible hose?
Is it possible to make revision drawings in plain AutoCAD Plant 3D / P&ID?
Unable to overwrite isometric drawing in Plant collaboration projects with BIM 360 Team
How to adopt the bill of material (BOM) of an isometric drawing to show both port sizes of a valve
An item with the same key has already been added
Crash when creating an isometric if “Long Description (Size)” will be used for the bill of material ...
Is it possible to sort the bill of material for orthographic drawings by letters instead of numbers?
Renaming a folder in project manager won’t be reflected in Windows Explorer
AutoCAD Plant 3D: How to get bolts to display as sets in Isometric BOMs
AutoCAD Plant 3D: Part categories won’t be shown in catalog
Crash when starting AutoCAD Plant 3D
Error: “An item with the same key has already been added” when creating an isometric drawing
If the body of a control valve will be substituted by another, the layer of the body changes
Is it possible to integrate the information of “Cont’d On” in the title block of an isometric drawin...
Plant 3D : Unable to use duplicate component in Spec editor
What exactly is mentioned with End 1 and End 2 in the piping connection settings?
AutoCAD P&ID: Create connection dialog does not show the OK, Canel or Help buttons
AutoCAD Plant 3D: How to edit the default Actuator Height and Width in the Spec
VCLIP Plugin for AutoCAD Plant 3D
When connecting a dummy leg support to piping it is inserted one size smaller than the piping.
Set a default path for Data Manager exports
AutoCAD P&ID: Cannot edit equipment weight property in Data Manager
AutoCAD Plant 3D: Edit catalog component dimensions
AutoCAD Plant 3D: Is it possible to connect components from different specs
AutoCAD Plant 3D: Pipe connections for XREFs shows as OPEN END in isometric
How to separate the spool numbers by Field Fit Weld in AutoCAD Plant 3D
What are the differences between Vault projects and Collaboration projects?
When opening a project from the Collaboration Hub in Plant 3D an error is displayed
An unknown error has occurred - PnPCompletionStatus.RelationshipTypeDoesNotExist when opening P&ID D...
AutoCAD Plant 3D XREF Properties do not display in Navisworks
AutoCAD Plant 3D: Content cannot be used because the shared content folder is not available
AutoCAD Plant 3D: Supports inherit properties from pipe in isometric BOM
AutoCAD Plant 3D: Update 2017.1.1 in comparison to 2017.0.2
Is it possible to hatch structural sections automatically in orthographic drawings?
Line numbers disappearing on valves and other components
P&ID Line List empty
AutoCAD Plant 3D Spec Editor cannot read network drive
AutoCAD Plant 3D: Possibility to run the Create Project Backup utility outside of the Project Manage...
Crash when using 3D Orbit in AutoCAD Plant 3D
Plant 3D Report Creator: How to create a calculated function
How to get the default control valve to change in AutoCAD P&ID and Plant 3D
How to show dimension sizes of parameter graphics in the property palette?
July 2017
Faulty display of the node “Title block and Display” in the project setup
User Defined Table list in Plant Isometrics
Weld points won`t be shown although PLANTWELDDISPLAY is activated
When inserting a component defined by a custom block, it is too big
Wrong scaling if a British block-based component will be inserted in a mixed-metric project
Missing Flanges, Fittings, and Valves in Plant 3D model
Monitoring AutoCAD Plant Collaboration Services through Autodesk Health Dashboard
Plant 3D 2017 : Ortho View lost association with model after Vault Migration
Possibility to setup a master drawing which can be used for slaved drawings but with different tags
Isometric drawing fields not displayed
How to set the weld number continue if the Isometric DWG is divided over multiple sheets in AutoCAD ...
How to Connect Lap Joint Flanges in AutoCAD Plant 3D
Graphic error during piping
Hand Valves disappear when entering and exiting project setup
For some slines in a drawing the context menu command “Edit sline Group…” is not available
Error when checking “Show all Linenumbers”
Error when export to xls format from Spec and Catalog Editor in AutoCAD Plant 3D
Custom pipe supports are not dimensioned or shown on the Isometric BOM in AutoCAD Plant 3D
Bill of material (BOM) won’t be updated when orthographic view will be updated
AutoCAD Plant 3D 2017 Update 0.2 from Autodesk Desktop App cannot be installed
AutoCAD Plant 3D crashes when opening a file
AutoCAD Plant 3D: Attempt to write a read-only database
AutoCAD Plant 3D: Cannot place an equipment in the model
AutoCAD Plant 3D: Dynamic input dots are too large
AutoCAD Plant 3D: Error message when executing AUDITPROJECT for a project
AutoCAD Plant 3D: For a specific model it fails to create an ortho drawing from a specifc side
AutoCAD Plant 3D: How to create a clamp connection?
AutoCAD Plant 3D: How to synchronize specs and catalogs from the content folder in a Vault environme...
AutoCAD Plant 3D: Missing geometry of user-defined block component in the catalog
AutoCAD Plant 3D: Modeling Operation Error: Error Code Number is 98066 when using EXPORTTOAUTOCAD
AutoCAD Plant 3D: There are a lot of waterdrops in the drawing
AutoCAD Plant 3D: Trimming structural members to more than one plane
June 2017
AutoCAD Plant 3D: Add reducer to a TEE(RED) in the branch table
How to create a shaded or grayscale ortho view in AutoCAD Plant 3D
How to configure AutoCAD Plant 3D isometrics for specific needs
How to export an AutoCAD Plant 3D model to SolidWorks?
Is is possible to change the order of the size values of an olet?
Plant 3D: How to keep layer information from the model in orthographic drawings
How to create THDF/THDM connection with a valve and a nipple
Flow arrow will be dimensioned in the isometric drawing
How to annotated the cutback angle without decimal places
How to reduce the count of sheets for isometric drawings
AutoCAD Plant 3D: How do I include the bend radius in BOM
AutoCAD Plant 3D: Performance problems after running isometrics with LDT
AutoCAD Plant 3D: Project Manager does not open
Error during creation of an isometric drawing: “There was an error reading from the pipe: Unrecogniz...
Export from Data Manager does not show option for .xlsx file extension
How to move a drawing from tab “Source Files” to tab “Orthographic DWG”
When creating a new catalog component the end type selection list is empty
AutoCAD Plant 3D: Section view error when creating orthographics
AutoCAD Plant 3D: Unable to Open Project: no such table PnPTables
Isometric: Open End End Connection annotation not shown on ISO
AutoCAD Plant 3D: Fittings plot black, as opposed to the color assigned to the layer
During migration of a project an error pops up and the migration fails
German version: When opening a symbol block of a P&ID symbol the block editor is empty
Slow performance of models and drawings in AutoCAD Plant 3D
AutoCAD P&ID objects insert at the wrong scale
How to get and use the Tuchenhagen catalog for AutoCAD Plant 3D
How to import Inventor files in Plant 3D
Is it possible to save the settings of data manager permanently?
Report Creator - Value cannot be null error occurs when opening the project.xml
The Eccentricity of the equipment shapes Round-to-Rectangle is not working in AutoCAD Plant 3D
The Spears Content reducer cannot connect to the pipe in AutoCAD Plant 3D
AutoCAD Plant 3D: Unable to change Ortho folder path in Project Setup after project is created
Is СFD сompatible with AutoCAD Plant 3D?
P&ID Painter doesn’t work for external references (XREF)
Unable to bind XRefs that include Plant 3D drawings.
May 2017
AutoCAD P&ID: How to remove all tags of a project?
AutoCAD Plant 3D: How to copy a project
AutoCAD Plant 3D: How to suppress property change annotations for olets?
Enlarging the list of Object Mapping for valves in Pipe Spec Object Mapping
How to adopt German annotations to English annotations in isometric drawings
How to reduce the property string for an offpage connector by the last four characters?
How to rename folders in AutoCAD Plant 3D
How to utilize other disciplines in Plant 3D 2018 Collaboration
Is it possible to adopt the Check-iso styles by merging different isometric tables in one overflow a...
Linear weights and weights for structural members
Utilizing template projects for AutoCAD Plant 3D
What are the new features of AutoCAD Plant 3D from 2014 till 2017?
After installing update 1 or update 1.1 for AutoCAD Plant 3D 2017 some commands/properties are not w...
AutoCAD P&ID: Custom inline symbol with flow direction
AutoCAD P&ID: Drawing validation removes leading zeros from Tag number
AutoCAD Plant 3D 2017 Update 1 Non-English: Drawings cannot be removed from project
AutoCAD Plant 3D 2018: No command “Compress database” available anymore
AutoCAD Plant 3D: Components incorrectly drawn on Existing layer in isometric drawing
AutoCAD Plant 3D: Plastic valves with end type PSW, don’t display dimensions (length or center) on I...
Just In Time (JIT) error when adding services in AutoCAD Plant 3D
AutoCAD P&ID: When adding a segment breaker an error message pops up
Model with branch pipes using connectionoffset will be split in multiple isometric sheets
Orthographic view is unusable or broken
Plant 3D drawings are longer associated with a project
Plant 3D Imperial / Metric / Mixed Metric Project Drawing Compatiblity
SQL Server is missing in Plant 3D
Unrecognized error when creating an isometric drawing with existing pipes connected to new pipes
April 2017
AutoCAD Plant 3D: How to include a valve tag in the isometric drawing
AutoCAD Plant 3D: How to suppress specific weld dots in isometric drawings
AutoCAD Plant 3D: Is it possible to show the text of the structure grid in an orthographic drawing?
How to adjust size of reinforcement pads in AutoCAD Plant 3D
How to wrap a text of a field in a report created by the Report Creator?
After deleting the line number tag of a disconnected pipeline the line number tag of the formerly co...
AutoCAD Plant 3D: How to configure isometric drawings
AutoCAD Plant 3D: How to create a wafer connection without a gasket
AutoCAD Plant 3D: Is is possible to present the pipeline only by centerlines?
AutoCAD Plant 3D: Which port of a tee is port 1, 2 and 3?
How to remove the need of uniqueness of a pipeline tag
Valves and Actuators: possible combinations, what works and what doesn’t work
AutoCAD Plant 3D locks up when trying to access the Project Setup
It is not possible to edit the actuator of a valve in the model
The position of a user-defined angle valve is wrong in the isometric drawing
Adding a property to catalogs by size rather than as a general property
AutoCAD Plant 3D: Is it possible to show elevation of a pipe at the support
AutoCAD Plant 3D: Property “Insulation Type” is not visible in the property palette for a pipeline
AutoCAD Plant 3D: Updating or creating Ortho view results in an empty viewport.
AutoCAD Plant 3D: Missing drawings in project manager
Error message “FAILURE - eFileNotFound” when creating an isometric drawing
Isometric error in AutoCAD Plant 3D: “FAILURE: Object reference not set to an instance of an object”
Long description styles do not update when using custom properties
Plant 3D : How to get Pipe Specs folder in Project browser
AuotCAD Plant 3D Specs and Catalog Editor is missing Parametric size information
Project settings check out box is in the background in AutoCAD Plant 3D 2018
The isometric generation process stops at 30 minutes in AutoCAD Plant 3D
Weld symbols do not appear on plastic pipe in AutoCAD Plant 3D 2017
When opening in a 3D model in AutoCAD Plant 3D an error is displayed: The File Exists
March 2017
Unable to open project from Vault in Plant 3D as user is logged out of Vault
Unable to make changes to AutoCAD Plant 3D and P&ID project settings in an active project
Plant 3D: Orifice Plate not shown in 3D Parts Report Creator report
Configuring custom property with = symbol in Offpage Connector gives “Invalid argument Tag in settin...
Collaborating AutoCAD P&ID/Plant 3D projects via OneDrive
When creating an isometric drawing the geometry is far outside of the title block
Plant 3D: Can’t Change the Color of Instrumentation Symbol
AutoCAD Plant 3D: Add the M prefix designation to metric bolts in the isometric BOM.
User-defined connection text for “Cont’d On”-connections won’t be shown
Pipes with fix length won’t be shown in the bill of material (BOM) of the isometric drawing
Segment breaker annotation doesn’t switch after rotating by 180°
A value of a hand valve won’t be updated if it will be substituted by another hand valve with a diff...
How to create a report which groups separately equipments and valves?
Adding custom properties for colors in AutoCAD Plant 3D color and layer settings
When trying to open a project from Vault on AutoCAD Plant 3D 2017 an error is displayed
When updating an orthographic drawing in AutoCAD Plant 3D the annotations shift
Block Based components are invisible in AutoCAD Plant 3D
How to make AutoCAD Plant 3D models generate correct ortho views
How to create a custom part in AutoCAD Plant 3D using an AutoCAD block
AutoCAD Plant 3D: Pipe does not appear in drawing after clicking routing points
AutoCAD Plant 3D: Missing supports in the tool palette
How to adopt the colors of the isometric drawing of the specific components
February 2017
Project manager does not work correctly in AutoCAD Plant 3D 2017
Specific joints stop functioning in AutoCAD Plant 3D
How to create a report for structure components via Report Creator
How to create a report via Report Creator showing all supports
How to get a report in the Report Creator where the fittings and the pipe run components are listed ...
How to reactivate the default value of an acquisiton from one top-level class to lower-tier class
AutoCAD Plant 3D crashes when generating orthographic drawings
Revit: Bringing AutoCAD Plant 3D DWGs into Revit
AutoCAD Plant 3D and P&ID: Vault “Enforce Unique File Names” for Plant drawings
AutoCAD Plant 3D: How to use a compass in user-defined coordinate system (UCS)
Error: The format expression string cannot be longer than 255 characters.
How to create a custom inline socket
Property acquisitions not updating after copying segments in AutoCAD Plant 3D
Unable to assign Size and Spec to line segments in AutoCAD Plant 3D
How to bring a Plant 3D model into a Revit project
AutoCAD Plant 3D: Color assignment for a custom component does not work
German version: If a nozzle should be added onto a nozzle on an equipment two fields are on top of e...
Modifying Tap-Joint setup breaks olet connections in AutoCAD Plant 3D
Wrong parameter list for bent nozzles in AutoCAD Plant 3D
When connecting a stanchion support to piping it is inserted one size smaller than the piping
Is it possible to add a stub-in on a reducer?
How to customize the shown properties of the dialog ‘View Connected Offpage Connector’
AutoCAD Plant 3D: Different behavior of the compass for elbows and bends
Cannot add pipe to equipment nozzle
Isometric components are placed on existing the existing layer in AutoCAD Plant 3D
The P&ID Painter tool doesn’t apply to all objects AutoCAD Plant 3D and P&ID
How to annotate spool numbers on isometric drawing at welds
What is the difference between SQL Server Standard and SQL Server Express?
Marking via PLANTPIDLINELIST available equipments if they are used or not
AutoCAD Plant 3D: How to add a tangential nozzle for a tank?
AutoCAD Plant 3D: Is it possible to create a list of different flange connection types?
January 2017
Is it possible to use dynamic blocks for block-based components in AutoCAD Plant 3D?
How to use ManHandWay for a non-listed metric size for an equipment
Valves of a custom spec won’t be used by PLANTPIDLINELIST
Matt DiMichele
