Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for AutoCAD Plant 3D?
Solved by matthew.d. Go to Solution.
December 2017
November 2017
October 2017
September 2017
August 2017
July 2017
June 2017
May 2017
April 2017
March 2017
Unable to open project from Vault in Plant 3D as user is logged out of Vault
Unable to make changes to AutoCAD Plant 3D and P&ID project settings in an active project
Plant 3D: Orifice Plate not shown in 3D Parts Report Creator report
Collaborating AutoCAD P&ID/Plant 3D projects via OneDrive
When creating an isometric drawing the geometry is far outside of the title block
Plant 3D: Can’t Change the Color of Instrumentation Symbol
AutoCAD Plant 3D: Add the M prefix designation to metric bolts in the isometric BOM.
User-defined connection text for “Cont’d On”-connections won’t be shown
Pipes with fix length won’t be shown in the bill of material (BOM) of the isometric drawing
Segment breaker annotation doesn’t switch after rotating by 180°
A value of a hand valve won’t be updated if it will be substituted by another hand valve with a diff...
How to create a report which groups separately equipments and valves?
Adding custom properties for colors in AutoCAD Plant 3D color and layer settings
When trying to open a project from Vault on AutoCAD Plant 3D 2017 an error is displayed
When updating an orthographic drawing in AutoCAD Plant 3D the annotations shift
Block Based components are invisible in AutoCAD Plant 3D
How to make AutoCAD Plant 3D models generate correct ortho views
How to create a custom part in AutoCAD Plant 3D using an AutoCAD block
AutoCAD Plant 3D: Pipe does not appear in drawing after clicking routing points
AutoCAD Plant 3D: Missing supports in the tool palette
How to adopt the colors of the isometric drawing of the specific components
February 2017
Project manager does not work correctly in AutoCAD Plant 3D 2017
Specific joints stop functioning in AutoCAD Plant 3D
How to create a report for structure components via Report Creator
How to create a report via Report Creator showing all supports
How to get a report in the Report Creator where the fittings and the pipe run components are listed ...
How to reactivate the default value of an acquisiton from one top-level class to lower-tier class
AutoCAD Plant 3D crashes when generating orthographic drawings
Revit: Bringing AutoCAD Plant 3D DWGs into Revit
AutoCAD Plant 3D and P&ID: Vault “Enforce Unique File Names” for Plant drawings
AutoCAD Plant 3D: How to use a compass in user-defined coordinate system (UCS)
Error: The format expression string cannot be longer than 255 characters.
How to create a custom inline socket
Property acquisitions not updating after copying segments in AutoCAD Plant 3D
Unable to assign Size and Spec to line segments in AutoCAD Plant 3D
How to bring a Plant 3D model into a Revit project
AutoCAD Plant 3D: Color assignment for a custom component does not work
German version: If a nozzle should be added onto a nozzle on an equipment two fields are on top of e...
Modifying Tap-Joint setup breaks olet connections in AutoCAD Plant 3D
Wrong parameter list for bent nozzles in AutoCAD Plant 3D
When connecting a stanchion support to piping it is inserted one size smaller than the piping
Is it possible to add a stub-in on a reducer?
How to customize the shown properties of the dialog ‘View Connected Offpage Connector’
AutoCAD Plant 3D: Different behavior of the compass for elbows and bends
Cannot add pipe to equipment nozzle
Isometric components are placed on existing the existing layer in AutoCAD Plant 3D
The P&ID Painter tool doesn’t apply to all objects AutoCAD Plant 3D and P&ID
How to annotate spool numbers on isometric drawing at welds
What is the difference between SQL Server Standard and SQL Server Express?
Marking via PLANTPIDLINELIST available equipments if they are used or not
AutoCAD Plant 3D: How to add a tangential nozzle for a tank?
AutoCAD Plant 3D: Is it possible to create a list of different flange connection types?
January 2017
Is it possible to use dynamic blocks for block-based components in AutoCAD Plant 3D?
How to use ManHandWay for a non-listed metric size for an equipment
Valves of a custom spec won’t be used by PLANTPIDLINELIST
