lapped joint connection
hello,
i'm at my wits end here.
so i'm in george fisher catalog/spec. i create a lapped flange ,see screen shot. but i cant connect anything to it! nothing! its so frustrating!
i know this is probably a connector issue but i cant figure it out.
please help
adrian
take screen shot from Connection Port Properties in spec editor  and check matching pipe od.
rnoordam
A lapped flange (port1=FL, port2=LAP) need a slip-on hub flange (port1=LAP, port2=BV) to connect.
Than a proper gasket (if lapped flange has RF face and a pressure class is 150 than the gasket also)..
And a Boldset  (if lapped flange has RF face and a pressure class is 150 than the Boldset also)..
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Rene Noordam
CADAC
HI Rene,
Sorry for my slow reply.
thanks for your help on this.
adrian
Imogollon1011
Estimados yo tengo un problema similar con la junta lapped pero a las hora de crear un isométrico
no me sale las coordenadas ni mucho menos la continuación con la otra lineal que esta se conecta como puedo proceder
