Stub end connection missing from catalog
hello, am i missing something here?
i add a lapped flange to my spec. fine.
but i cant find a stub end to add???
i'm using DIN EN Pipes and fittings v1.1 en out of the box.
thanks for your help
adrian
patpat79
You mean there is no Stub end component from catalog to add on your spec? have your tried to create or open other catalog like ASME then copy and paste it to yours? Just an idea, many thanks.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
rnoordam
Have you tried the "slip-on hub flange DIN EN 1092-1...."
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Rene Noordam
CADAC
ryan.bales
Autodesk Support
Autodesk Support
I installed the content pack and located it. It looks like it's called "Welding neck Collar"
Ryan Bales
Fusion 360 Product Support
Ryan,
that's it! why its under that heading i don't know but thanks a million!
now if only i could connect a wafer valve to it i could sleep at night!
thanks again
Adrian
