AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Issue with Spool Splitting
4 REPLIES 4
santoshbaraiya
227 Views, 4 Replies
I have made a model and all the parts are given a single spool name. When I try to generate Spool ISO with option of spool naming and sizing methods as follows from project setup:
I want to beak spools only when the spool name is changing. For example Spl-001 and Spl-002 are two spools, so when spool name changes, I want to split the drawings, so there should be 2 spool drawings. But in my case I gave the spool name 12345. So there is one spool but when ISO is generated, it shows me the 3 models and 4 spools.
Can anyone help me to show how to stop model splitting?
I have attached the ISO config file also for reference
4 REPLIES 4
I'm not sure if this will help, but could you please upload the PCF file?
Do all parts have a symbol type and symbol key set?
Shuji Sakuma - Japan
https://www.youtube.com/@AUTOCAD-PLANT-3D-FOR-JAPANESE
Yes all the skey has symbols, so that was not the issue
I resolved the issue by turning model splitting off from the ISOCONFIG file
Ok. I understand.
