AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Isometrics
6 REPLIES 6
924 Views, 6 Replies
Isometrics
Hello!
I have a problem with generating isometrics in my projects...
How do I have to configure my project setup not to get something like that (attached screenshots) - everything on different sheet.
I will be grateful for your help because I got stucked and can't go on 😞
UPDATE:
"Toggle Disconnect markers" checked - no problems with disconnections
Labels (3)
6 REPLIES 6
h_eger
Dear @Anonymous ,
you can upload the file "IsoCreationLog.txt" from your Iso directory.
Maybe it says why your iso is not created correctly.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
in reply to: h_eger
It says:
1 Isometric(s) successfully created with no error conditions:
    O:\...............\Isometric\A0\PCFs\UserDefinedLine.pcf
INFO    - Loading input: 'O:\.............\Isometric\A0\PCFs\UserDefinedLine.pcf'
INFO    - Loaded '13' model(s).
INFO    - Processing: 'UserDefinedLine-1'.
WARNING - No break points have been specified.
INFO    - Model-split has been skipped.
INFO    - Processing: 'UserDefinedLine-2'.
INFO    - Processing: 'UserDefinedLine-3'.
INFO    - Processing: 'UserDefinedLine-5'.
INFO    - Processing: 'UserDefinedLine-6'.
INFO    - Processing: 'UserDefinedLine-7'.
INFO    - Processing: 'UserDefinedLine-8'.
INFO    - Processing: 'UserDefinedLine-9'.
INFO    - Processing: 'UserDefinedLine-10'.
INFO    - Processing: 'UserDefinedLine-11'.
INFO    - Processing: 'UserDefinedLine-12'.
INFO    - Processing: 'UserDefinedLine-13'.
INFO    - Processing: 'UserDefinedLine-14'.
No break points? What should I do?
h_eger
This is a "User Defined Line", so please test a production ISO for this line to see if the same phenomenon occurs.
Hartmut Eger
Senior Engineer
XING | LinkedIn
in reply to: h_eger
Thanks a lot for help, production iso works well.  Now I have much less isometrics!
Just one last question - as attachded on screen shot - I have a lot of "open ends" - what does it mean? Can I configure it to be said where the connection goes to?
h_eger
Dear @Anonymous ,
Open ends are all pipelines that have no connection to equipment or another pipeline.
You can see from the picture of the model that the pipes have no connection.
You can only change this manually or complete your model.
Hartmut Eger
Senior Engineer
XING | LinkedIn
