AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Isometric(s) created with reported error conditions
3 REPLIES 3
nurul
435 Views, 3 Replies
nurul
Hi. I have a custom template/titleblock for isometric drawing. However when generate iso dwg, it shows some error. the .dwg still ok, just something to do with pcf (refer attach).
I actually do not need the .pcf to be generated. is there away to solve this?
3 REPLIES 3
h_eger
in reply to: nurul
h_eger
Dear @nurul ,
don't let the "IsoCreationLog.txt" file confuse you.
In the 2021 version, the content is reduced to the essentials.
Wire you have already written the iso drawing has been created, the warnings are just a misleading message.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Dear @nurul ,
Hartmut Eger
Senior Engineer
XING | LinkedIn
George.Endrulat
in reply to: h_eger
George.Endrulat
Have you tried converting the PCF to a 3D model in Plant3d or importing the PCF into Caeser?
George
If my post offers a solution, please click "Accept as Solution"
George
h_eger
in reply to: George.Endrulat
h_eger
Dear @George.Endrulat ,
no, until now we have only used the PCF export for Sigma Rohr 2 and the PCF import from Sigma Rohr 2
Hartmut Eger
Senior Engineer
XING | LinkedIn
Hartmut Eger
Senior Engineer
XING | LinkedIn
