Hi. I have a custom template/titleblock for isometric drawing. However when generate iso dwg, it shows some error. the .dwg still ok, just something to do with pcf (refer attach).
I actually do not need the .pcf to be generated. is there away to solve this?
Solved by h_eger. Go to Solution.
Dear @nurul ,
don't let the "IsoCreationLog.txt" file confuse you.
In the 2021 version, the content is reduced to the essentials.
Wire you have already written the iso drawing has been created, the warnings are just a misleading message.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Dear @nurul ,
Hartmut Eger
Senior Engineer
XING | LinkedIn
Have you tried converting the PCF to a 3D model in Plant3d or importing the PCF into Caeser?
Dear @George.Endrulat ,
no, until now we have only used the PCF export for Sigma Rohr 2 and the PCF import from Sigma Rohr 2
Hartmut Eger
Senior Engineer
XING | LinkedIn
Hartmut Eger
Senior Engineer
XING | LinkedIn
