Isometric Item Callout Arrow Size
_Jeff_Roy_
Message 1 of 11
_Jeff_Roy_
Our isometrics are generating fairly well but one issue is the arrow size for our numbered item callouts. They're coming in at too small a scale and we'd like for them to match the dimension arrow size. Just trying to locate the setting where the scale of these graphics can be modified. They're identified as multileaders and AdskIso is the multileader style. This is an example of how small the multileader arrows are (arrow outlined in pink):
Looking at the applicable dimension and multileader styles in Plant 3D while I have the isometric open, the arrow size for both is set as 0.1000. However, when I select a dimension in the isometric, the arrow size is shown as 2.5 in the Properties window.
I'm not worried about the dimensions, we're happy with the size. If someone can point me toward the setting that controls the item callout arrow sizes for isos it would be appreciated.
Replies (10)
Message 2 of 11
h_eger
Dear @_Jeff_Roy_ ,
The answer is not easy to find. I changed the setting of the BOM elements with the arrow and everything was OK.
As we do not know your ISO configuration, it will be difficult to find a solution.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 11
_Jeff_Roy_
@h_eger Thank you for the reply. Can you tell me where you updated the arrow size in your configuration?
Message 4 of 11
h_eger
@_Jeff_Roy_ ,
I have not updated anything it is the Iso Standard Final_A2
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 5 of 11
_Jeff_Roy_
Deleted
Message 6 of 11
h_eger
@_Jeff_Roy_ ,
But I do!
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 7 of 11
_Jeff_Roy_
@h_eger Thank you for the screenshots! However, I'm on 2022 and my annotations screen does not have the options shown in your image.
Do you know how I can access those settings in my version of the software?
Message 8 of 11
h_eger
@_Jeff_Roy_ ,
it would be very thoughtful of the users of this forum to include such information in the first post so that we are not led down the wrong track or!
the remaining work is identical between P3D 2022 and P3D 2024
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 9 of 11
_Jeff_Roy_
@h_eger Thanks very much, this did it!
Message 10 of 11
_Jeff_Roy_
@h_eger I don't suppose you'd have insight into how we might address the other iso issue we're experiencing from this thread...?
Message 11 of 11
h_eger
@_Jeff_Roy_ ,
I have read the article but there is no real solution yet. See @DVaquand
Hartmut Eger
Senior Engineer
XING | LinkedIn
