AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Isometric Annotation Leader arrow sizes not consistent
4 REPLIES 4
jhunix2022
353 Views, 4 Replies
Is there anyone here who encountered inconsistent arrow sizes on their generated isometric? My isometric output always has this inconsistency on leader arrow sizes. Is there any work around to this or any way to fix this issue?
Please see image below. The red circle are the ones that have different sizes and the magenta color is the exact size that I set.
Any information would greatly be appreciated. Thanks a lot.
4 REPLIES 4
jabowabo
in reply to: jhunix2022
Can you provide your isoconfig.xml file?
jhunix2022
in reply to: jabowabo
Hi @jabowabo,
Attached is my isoconfig.xml.
Thanks.
jabowabo
I'm not set up for metric projects to test thoroughly but it looks like the leader arrow is scaling per the AnnotationStyle definition for the flange/bolt/gasket group. You may need to test using a different annotation scheme or modifying some of these values in a test iso style environment to narrow down what is acting on this.
jhunix2022
Hi @jabowabo,
Thanks for your response.
I don't think the annotation style would affect the size of the leader arrow. I already tried changing the annotation style from Scale Rectangular to just the normal rectangle and adjusted the annotation scale factor to 2.5 (default number), but the results remains the same. I am not sure what is causing this but hopefully this can be fixed.
