Is it possible to indicate the start point for a pipeline so that spool numbers follow the correct direction similar to the Isogenstartpoint command in CadWorx.
Our spool numbers follow flow direction.
I am afraid this isn't possible at the moment. However I can log this as a enhancement request with our development team and keep you posted.
I will also check whether there are anyother alternatives for this issue.
how about just keeping the ISO's in order as you go along a pipeline.
Currently, when dumping multipage ISO's, they 'jump' all over the place.
eg
sheet 1 - from sheet 3 to equip.
sheet 2 - from sheet 3 to sheet 5
sheet 3 - from sheet 1 to sheet 2
sheet 4 - from sheet 5 to header
sheet 5 - from sheet 2 to sheet 4
flow arrows go from header to equip!
The start point is already on the request list.
I asked this question back in 2012, I am currently using 2018, I know I can reverse the order in the advanced options but it would be good to have it saved in the model. I thought Start Point might solve the issue but alas no.
Anybody any other ideas
