AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
ISO missing instrument Part number
4 REPLIES 4
traiduong014969
324 Views, 4 Replies
Hi Autodesk Support,
I have a problem with creating bom in isometric. all fitting and instrument have number in bom tabe , however, the instrument was missing part number. You can see picture below. I reference link a post about this problem but it not working for me.
https://forums.autodesk.com/t5/autocad-plant-3d-forum/instrument-angle-psv-valve-bubble-tag-not-show...
For more clarification refer to the attached setup file
Thanks in advance !
4 REPLIES 4
h_eger
in reply to: traiduong014969
Dear @traiduong014969 ,
If you follow this link exactly, it will work with the instruments!
https://knowledge.autodesk.com/support/autocad-plant-3d/learn-explore/caas/sfdcarticles/sfdcarticles...
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
traiduong014969
in reply to: h_eger
Thank you so much, I do follow the guide link step by step, and its working
how you pass through this?
Do you copy this IsoConfig.xml file somewhere so custom parts to appear in iso sketches?
Regards
yep, i folow link Mr h.eger step by step and Its working
Technology Administrators
AutoCAD Beta
