AutoCAD Plant 3D Forum
ISO Annotation Note Config request
2 REPLIES 2
kkakka0901
307 Views, 2 Replies
isoconfig.xml How do I modify it?
2 REPLIES 2
Ray_K
in reply to: kkakka0901
Try adding to IsoConfig.xml:
<ComponentScheme Name="Valve_AA" AnnotationStyle="Rectangle" Enabled="true" Grouping="true" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="AlwaysNonArrowed" Filter="Valve" Fields="AA" />
<ComponentScheme Name="Valve_BB" AnnotationStyle="Standard" Enabled="true" Grouping="true" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="AlwaysNonArrowed" Filter="Valve" Fields="BB" />
Try adding to Iso.atr under BOM-ATTRIBUTES
Valve.AA
Valve.BB
note: make sure that the attributes added to the config & iso.atr files matches the attributes created within Plant 3D
hope this help.
kkakka0901
in reply to: Ray_K
thank you.
It's all thanks to you
Technology Administrators
AutoCAD Beta
