I have written one command which does some operation on the object that is selected in AutoCAD plant3D drawing. The workflow is such a way that user selects the object and then calls the command. I am using Editor.GetSelection() API to get the object selected in the drawing, however when no object is selected in the drawing this API prompts user to select the object, but in this case I want to terminate the operation.
Is there any way/API which can tell me that no object is selected in drawing without prompting the user for object selection so that I can terminate the operation programmatically via .NET
