When plotting the P&ID, the symbols in the PDF layer are not hidden correctly. A part always remains on layer 0. Everything is set correctly in the block and the symbol definition. I have already tried all plotter drivers and also various PDF programs. All combinations with the same result.
Solved by Michiel.Valcke. Go to Solution.
It looks like the issue only happens with the ISO P&ID style (cannot recreate it in PIP). I noticed that the block definition of the ISO General Valve are 4 separate lines. I edited the block definition by joining the 4 lines into a single polyline and the issue was resolved.
