AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Insert weld socket
3 REPLIES 3
ojaH4RD3
186 Views, 3 Replies
Insert weld socket
I'm trying to insert a weld socket to a pipe. For instruments like pressure gauges and temperature, we often drill a whole in the pipe and weld on a threaded socket. (1" of 1/2")
Is this possible to do in Plant 3D?
The spec I'm using is 16HS01.
3 REPLIES 3
h_eger
in reply to: ojaH4RD3
Dear @ojaH4RD3 ,
yes, it is easy to create a weld-on socket as an OLET in the catalog and assign it to the pipe spec.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
ojaH4RD3
in reply to: h_eger
Hi, thanks for your answer. However, I'm trying to make a Olet, but it always gets the same size as the pipe it is inserted to.
h_eger
Dear @ojaH4RD3 ,
please create an outlet for each nominal width, otherwise it will not work automatically.
Hartmut Eger
Senior Engineer
XING | LinkedIn
