How to welds be on top insulation or dimensions lines
AlekVesko
AlekVesko
Good day,
do anyone know, how to make weld symbol on top of  any other lines. I try so many times but its not working with welds, rest is ok.
 Please check pict.
h_eger
Dear @AlekVesko ,
can you please describe in more detail what you want I don't understand exactly what you want to have displayed on the isometry with the welds
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
AlekVesko
Thank you @h_eger for answering again, great!
Please, on my picture, can you check weld no. 12. You can see, that insulation lines is under (or top) of that annotation.
You can check annotation for pipe is ok, but weld not. And its always like that, what ever I do, weld be always mixed with insulation lines or dimensions. No dim break or similar for welds, but for rest, yes, its works.
AlekVesko
@h_eger any clue how to fix this?
Thank you upfront.
DVaquand
Hello
If you create a "mask" object (wipeout object) around the annotation symbol, and place this mask below the other objects, this should resolve the annotation overload problem.
== French ==
Si vous créez un objet "masque" autour du symbole d'annotation, et que vous placiez ce masque au-dessous des autres objets, cela devrez régler le problème de surcharge de l'annotation.
Cordialement
Dominique VAQUAND
www.dovaq.fr
Si mon message propose une solution, veuillez cliquer sur "Accepter comme solution"
If my post offers a solution, please click "Accept as Solution"
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
AlekVesko
Good day @DVaquand ,
thank you very much for your answer,
there is no way to make that annotation always with "mask"?
Because this problem is only with welds, other annotations are all ok, they are drawn on top of lines etc.
Thank you upfront.
