Dear @chetan.sakure ,
this would be a solution for you
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Also I need these NB values in mm not in inches.
Back to the first question: where does your serial number come from?
The link I sent you is only for a count number of the lines.
Now for the second question, you want to change the nominal size from mm to imperial "?
Hartmut Eger
Senior Engineer
XING | LinkedIn
no I want to change it from imperial to metric.
In what units is your Plant 3D project imperial or metric?
Hartmut Eger
Senior Engineer
XING | LinkedIn
It is in metric.
If the project is in metric units then the report in the Report Creator should also be displayed in metric units or your report templates are reprogammed to imperial units. I don't have the information to help you with this.
Hartmut Eger
Senior Engineer
XING | LinkedIn
