how to set serial number in report format?
chetan.sakure
Message 1 of 8
chetan.sakure
Can anyone tell me how to set serial number in report format?
Replies (7)
Message 2 of 8
h_eger
Dear @chetan.sakure ,
this would be a solution for you
https://knowledge.autodesk.com/de/support/autocad-plant-3d/learn-explore/caas/sfdcarticles/sfdcartic...
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 8
chetan.sakure
Also I need these NB values in mm not in inches.
Message 4 of 8
h_eger
Back to the first question: where does your serial number come from?
The link I sent you is only for a count number of the lines.
Now for the second question, you want to change the nominal size from mm to imperial "?
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 5 of 8
chetan.sakure
no I want to change it from imperial to metric.
Message 6 of 8
h_eger
In what units is your Plant 3D project imperial or metric?
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 7 of 8
chetan.sakure
It is in metric.
Message 8 of 8
h_eger
If the project is in metric units then the report in the Report Creator should also be displayed in metric units or your report templates are reprogammed to imperial units. I don't have the information to help you with this.
Hartmut Eger
Senior Engineer
XING | LinkedIn
