How to Insert Equipment via Command Line (LISP) Without Dialog Box – Like Block Insertion?
ehemmati
Message 1 of 11
ehemmati
Hi everyone,
I'm looking to insert multiple pre-saved equipment definitions in AutoCAD Plant 3D  without using the equipment dialog box.
My goal:
Use a LISP routine to insert a specific equipment type (already saved in the tool palette or catalog)
Control the whole process via command line, similar to using -INSERT for blocks
Pull insertion data (location, count, orientation, etc.) from an Excel sheet (which I can process with LISP or import separately)
I’m trying to automate placement for ~40–50 units and keep everything scriptable. Any ideas, sample code, or direction would be really appreciated!
Thanks in advance!
Replies (10)
Message 2 of 11
Moshe-A
@ehemmati ,
When you say i can process from excel the insertion point, scale, rotation - show us what you have?
post sample dwg containing a few blocks + an excel data file.
Moshe
Message 3 of 11
Sea-Haven
Providing Plant 3d supports get-application for Excel then you can read a Excel directly, choose a range or a do all. Do you have a program for the Excel part ?
Message 4 of 11
ehemmati
for example in the attached screen shot , you will see many electrical terminal blocks which I already defined each as an equipment ( to be considered in BOM and also weight of total skid). by now I manually insert those equipment one by one. i already developed a lisp code to insert them all based on an excel table which is a sample attached. the routine is also attached but this routine works for blocks not for plant 3d equipment. i am looking for a way to control the create equipment in plant 3d not with dialogue menu but with command line so that be able to create a similar code to insert equipment in dwg.
sample code for autocad blocks
(defun c:e3 ()
(command "undo" "begin")
(setq add (getvar "dwgprefix"))
(setq file (getfiled " Select Import File : " add "csv" 0))
(setq fil (open file "r"))
(setq po0 (getpoint " Basepoint "))
(setq x0 (car po0))
(setq y0 (cadr po0))
(setq Z0 (caddr po0))
(setq li nil)
(setq dinx 0)
(setq diny -2.0313)
(setq dinz -0.8891)
; (command "insert" "DIN16" "_non" po0 1 1 0)
(setq f 0)
(while (and (setq txt (read-line fil)) (/= txt ""))
(setq n (strlen txt))
(setq d1 "")
(setq d2 "")
(setq i 0)
(setq j 1)
(setq xxx 0)
(repeat n
(setq i (1+ i))
(setq let (substr txt i 1))
(if (/= let ",")
(cond
((= j 1) (setq d1 (strcat d1 let)))
((= j 2) (setq d2 (strcat d2 let)))
(setq j (1+ j))
(setq f (1+ f))
(if (OR (= D2 "DIN16") (= D2 "din16"))
(setq li (append li (list (list "DIN16" d1 "0" "2.0313" "0.8891" f "0.25") ))))
(if (OR (= D2 "DIN14") (= D2 "din14"))
(setq li (append li (list (list "DIN14" d1 "0" "2.0313" "0.8891" f "0.25") ))))
(if (OR (= D2 "D") (= D2 "d"))
(setq li (append li (list (list "WDU25" d1 "0.0.3150" "-0.0848" "-0.0770" f "0.2008") ))))
(if (OR (= D2 "DG") (= D2 "dg")) (setq li (append li (list (list "WPE25" d1 "0.0.3150" "-0.0848" "-0.0769" f "0.2008" )))))
(if (OR (= D2 "A") (= D2 "a"))
(setq li (append li (list (list "WDU40" d1 "0.0.3150" "0.0487" "-0.0922" f "0.2402" ) ) )))
(if (OR (= D2 "AG") (= D2 "ag"))
(setq li (append li (list (list "WPE40" d1 "0.0.3150" "0.0021" "0.0001" f "0.2402" )))))
(if (OR (= D2 "B") (= D2 "b") (= D2 ""))
(setq li (append li (list (list "WAP" d1 "-0.0971" "-0.2567" "0.2591" f "0.0591" )))))
(if (OR (= D2 "E") (= D2 "e"))
(setq li (append li (list (list "WEW" d1 "0" "0" "0" f "0.3150")))))
(if (OR (= D2 "P") (= D2 "p"))
(setq li (append li (list (list "P" d1 "0.0.1148" "-3.2501" "-1.7735" f "1.3386")))))
(if (OR (= D2 "PLC") (= D2 "plc"))
(setq li (append li (list (list "PLC" d1 "0.0.3150" "1.7443" "0.9155" f "3.9370")))))
(if (OR (= D2 "F") (= D2 "f"))
(setq li (append li (list (list "FUSEHOLDER" d1 "0.3445" "0.7411" "0.7229" f "0.6890")))))
(if (OR (= D2 "N") (= D2 "n"))
(setq li (append li (list (list "NETWORKSWITCH" d1 "0" "0.5668" "-2.3591" f "4.5")))))
(if (OR (= D2 "R") (= D2 "r"))
(setq li (append li (list (list "RELAY" d1 "0" "1.7443" "-0.6485" f "1.5")))))
(if (OR (= D2 "FCM6AC") (= D2 "fcm6ac"))
(setq li (append li (list (list "FCM6ACIN" d1 "0" "1.7443" "-0.2599" f "0.5645")))))
(if (OR (= D2 "FCMANALOG") (= D2 "fcmanalog"))
(setq li (append li (list (list "FCMANALOG" d1 "0" "1.7443" "-0.2599" f "1.1613")))))
(if (OR (= D2 "PS2") (= D2 "ps2"))
(setq li (append li (list (list "POWERSUPPLY2" d1 "0" "-2.7814" "-1.8699" f "2.6772")))))
(if (OR (= D2 "WDK") (= D2 "wdk"))
(setq li (append li (list (list "WDK25" d1 "0" "1.7443" "0.9155" f "0.2008")))))
(if (OR (= D2 "WDKG") (= D2 "wdkg"))
(setq li (append li (list (list "WDK25G" d1 "0" "1.7347" "0.8891" f "0.2008")))))
(if (OR (= D2 "WDKB") (= D2 "wdkb"))
(setq li (append li (list (list "WDKB25" d1 "0" "1.7192" "0.8695" f "0.0591")))))
(if (OR (= D2 "ATF") (= D2 "atf"))
(setq li (append li (list (list "ATF" d1 "0" "1.7443" "0.9155" f "0.9252")))))
(if (OR (= D2 "F2") (= D2 "f2"))
(setq li (append li (list (list "FUSEHOLDER2" d1 "0" "1.7443" "0.9155" f "0.3110")))))
(setq xt x0)
(setq y y0)
(setq Z Z0)
(setq gg 1)
(foreach a li
(setq bn (car a))
(setq num (nth 1 a))
(setq dx (atof (nth 2 a)))
(setq dy (atof (nth 3 a)))
(setq dZ (atof (nth 4 a)))
(setq f (nth 5 a))
(setq w (atof (nth 6 a)))
(setq ang 0)
(if (= 3 (strlen num))
(setq ang 90)
(setq po1 (list xt y Z))
(setq po2 (list (+ xt dX dinx) (+ dy y diny) (+ dz z dinz)))
(setq xt (+ xt W))
(command "insert" bn "_non" po2 1 1 0)
(princ)
(close fil)
(command "undo" "end")
Message 5 of 11
Moshe-A
@ehemmati hi,
I see your are writing AutoLISP and would like to give you some guidelines:-
   i see your csv file contains only block names, from are you getting the insertion base point x/y factors
1. when a data file is involve, best practice first is to read all data records into autolisp memory (into a big list) than process it.
2. calling insert command as (command "-insert") will skip the std insert dialog box. if a block has attributes be aware of attdia & attreq sysvars
does this help you, or you need more?
Moshe
Message 6 of 11
ehemmati
please forget about my current lisp. my problem now is how to create equipment in plant 3d with command line. for blocks, i am ok but i am looking for some solution for equipment.
Message 7 of 11
Moshe-A
i do not have plant3d but have you tried what i said on 2?
Message 8 of 11
ehemmati
YES BUT WHEN USING PLANTEQUIPMENTCREATE WHITH - OR _ AGAIN THE DIALOG APPERS.
Message 9 of 11
DVaquand
Hello @ehemmati
I have put on my site an example and a principle of insertion, by AutoLISP programming, of block equipment.
Maybe this will help you and give you ideas.
The information is in French but easily understandable.
Here is the link: https://dovaq.fr/applications/
Search "Convertir des blocs AutoCAD en équipements divers Plant 3D"
Video https://screencast.autodesk.com/Embed/Timeline/f9b84eab-3dee-4668-a4fb-42550277595d
== French ==
J'ai mis sur mon site un exemple et un principe d'insertion, par programmation AutoLISP, des équipements blocs.
Peut-être cela pourra vous aider et vous donner des idées.
L'info est en français mais facilement compréhensible.
Voici le lien : https://dovaq.fr/applications/
Rechercher "Convertir des blocs AutoCAD en équipements divers Plant 3D"
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
Message 10 of 11
ehemmati
Thank you @DVaquand,
I found your solution very helpful. Based on that, I’m planning to change my approach: I’ll first insert blocks using LISP, and then immediately convert those blocks into Plant 3D equipment.
Now I have a follow-up question:
Is there a way to assign equipment properties (such as Manufacturer, Weight, Item Code, or Description) to the last converted equipment, using either LISP or command-line methods?
I’d like to automate that step too, so that each equipment item not only gets inserted but also has its properties filled out from an Excel sheet — without needing to open the Properties palette or Data Manager manually.
Thanks again for your time and support!
Message 11 of 11
jabowabo
Another approach would be to create your equipment in a separate library project, convert it to a block, then insert it from there with the explode on insert option.  You will not be able to modify any Plant 3D properties automatically via LISP - only via the .NET API.
