for example in the attached screen shot , you will see many electrical terminal blocks which I already defined each as an equipment ( to be considered in BOM and also weight of total skid). by now I manually insert those equipment one by one. i already developed a lisp code to insert them all based on an excel table which is a sample attached. the routine is also attached but this routine works for blocks not for plant 3d equipment. i am looking for a way to control the create equipment in plant 3d not with dialogue menu but with command line so that be able to create a similar code to insert equipment in dwg.
sample code for autocad blocks
(defun c:e3 ()
(command "undo" "begin")
(setq add (getvar "dwgprefix"))
(setq file (getfiled " Select Import File : " add "csv" 0))
(setq fil (open file "r"))
(setq po0 (getpoint " Basepoint "))
(setq x0 (car po0))
(setq y0 (cadr po0))
(setq Z0 (caddr po0))
(setq li nil)
(setq dinx 0)
(setq diny -2.0313)
(setq dinz -0.8891)
; (command "insert" "DIN16" "_non" po0 1 1 0)
(setq f 0)
(while (and (setq txt (read-line fil)) (/= txt ""))
(setq n (strlen txt))
(setq d1 "")
(setq d2 "")
(setq i 0)
(setq j 1)
(setq xxx 0)
(repeat n
(setq i (1+ i))
(setq let (substr txt i 1))
(if (/= let ",")
(cond
((= j 1) (setq d1 (strcat d1 let)))
((= j 2) (setq d2 (strcat d2 let)))
(setq j (1+ j))
(setq f (1+ f))
(if (OR (= D2 "DIN16") (= D2 "din16"))
(setq li (append li (list (list "DIN16" d1 "0" "2.0313" "0.8891" f "0.25") ))))
(if (OR (= D2 "DIN14") (= D2 "din14"))
(setq li (append li (list (list "DIN14" d1 "0" "2.0313" "0.8891" f "0.25") ))))
(if (OR (= D2 "D") (= D2 "d"))
(setq li (append li (list (list "WDU25" d1 "0.0.3150" "-0.0848" "-0.0770" f "0.2008") ))))
(if (OR (= D2 "DG") (= D2 "dg")) (setq li (append li (list (list "WPE25" d1 "0.0.3150" "-0.0848" "-0.0769" f "0.2008" )))))
(if (OR (= D2 "A") (= D2 "a"))
(setq li (append li (list (list "WDU40" d1 "0.0.3150" "0.0487" "-0.0922" f "0.2402" ) ) )))
(if (OR (= D2 "AG") (= D2 "ag"))
(setq li (append li (list (list "WPE40" d1 "0.0.3150" "0.0021" "0.0001" f "0.2402" )))))
(if (OR (= D2 "B") (= D2 "b") (= D2 ""))
(setq li (append li (list (list "WAP" d1 "-0.0971" "-0.2567" "0.2591" f "0.0591" )))))
(if (OR (= D2 "E") (= D2 "e"))
(setq li (append li (list (list "WEW" d1 "0" "0" "0" f "0.3150")))))
(if (OR (= D2 "P") (= D2 "p"))
(setq li (append li (list (list "P" d1 "0.0.1148" "-3.2501" "-1.7735" f "1.3386")))))
(if (OR (= D2 "PLC") (= D2 "plc"))
(setq li (append li (list (list "PLC" d1 "0.0.3150" "1.7443" "0.9155" f "3.9370")))))
(if (OR (= D2 "F") (= D2 "f"))
(setq li (append li (list (list "FUSEHOLDER" d1 "0.3445" "0.7411" "0.7229" f "0.6890")))))
(if (OR (= D2 "N") (= D2 "n"))
(setq li (append li (list (list "NETWORKSWITCH" d1 "0" "0.5668" "-2.3591" f "4.5")))))
(if (OR (= D2 "R") (= D2 "r"))
(setq li (append li (list (list "RELAY" d1 "0" "1.7443" "-0.6485" f "1.5")))))
(if (OR (= D2 "FCM6AC") (= D2 "fcm6ac"))
(setq li (append li (list (list "FCM6ACIN" d1 "0" "1.7443" "-0.2599" f "0.5645")))))
(if (OR (= D2 "FCMANALOG") (= D2 "fcmanalog"))
(setq li (append li (list (list "FCMANALOG" d1 "0" "1.7443" "-0.2599" f "1.1613")))))
(if (OR (= D2 "PS2") (= D2 "ps2"))
(setq li (append li (list (list "POWERSUPPLY2" d1 "0" "-2.7814" "-1.8699" f "2.6772")))))
(if (OR (= D2 "WDK") (= D2 "wdk"))
(setq li (append li (list (list "WDK25" d1 "0" "1.7443" "0.9155" f "0.2008")))))
(if (OR (= D2 "WDKG") (= D2 "wdkg"))
(setq li (append li (list (list "WDK25G" d1 "0" "1.7347" "0.8891" f "0.2008")))))
(if (OR (= D2 "WDKB") (= D2 "wdkb"))
(setq li (append li (list (list "WDKB25" d1 "0" "1.7192" "0.8695" f "0.0591")))))
(if (OR (= D2 "ATF") (= D2 "atf"))
(setq li (append li (list (list "ATF" d1 "0" "1.7443" "0.9155" f "0.9252")))))
(if (OR (= D2 "F2") (= D2 "f2"))
(setq li (append li (list (list "FUSEHOLDER2" d1 "0" "1.7443" "0.9155" f "0.3110")))))
(setq xt x0)
(setq y y0)
(setq Z Z0)
(setq gg 1)
(foreach a li
(setq bn (car a))
(setq num (nth 1 a))
(setq dx (atof (nth 2 a)))
(setq dy (atof (nth 3 a)))
(setq dZ (atof (nth 4 a)))
(setq f (nth 5 a))
(setq w (atof (nth 6 a)))
(setq ang 0)
(if (= 3 (strlen num))
(setq ang 90)
(setq po1 (list xt y Z))
(setq po2 (list (+ xt dX dinx) (+ dy y diny) (+ dz z dinz)))
(setq xt (+ xt W))
(command "insert" bn "_non" po2 1 1 0)
(princ)
(close fil)
(command "undo" "end")
