AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to create custom olet using autocad dwg block
3 REPLIES 3
dharunkumar.am
158 Views, 3 Replies
I need to insert a dwg block into the olet section. It's a clamp with a side outlet. I tried it with two and three ports, and it always tries to split the pipe into two pieces. How to make it work like an olet
This is how the 3d model looks like .
It is splitting the pipe into two pieces .
This is actually how it works .
3 REPLIES 3
h_eger
in reply to: dharunkumar.am
Dear @dharunkumar.am ,
Create as a user-defined block in the catalogue under the class OLET. Works very well.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
dharunkumar.am
in reply to: h_eger
I tried it the same way, but it didn't work. Can you share an image of the 3D model with plantpart-converted port points?
h_eger
Hartmut Eger
Senior Engineer
XING | LinkedIn
Technology Administrators
