I am trying to add specific P3Dlinegroup attribute to be included on isometrics continuation annotation but the P3D properties seems to be missing. I tested this on 2023, 24 and 25.
Refer to Autodesk Support website:
Solved by Michiel.Valcke. Go to Solution.
Solved by h_eger. Go to Solution.
@Ray_K ,
If you choose the manual option, it works very well. At least in P3D 2020, 2021, 2022, 2023, 2024 and 2025
<EndConnectionScheme Name="EndConnectionsPipe" AnnotationStyle="Standard" Format="FORTS. AUF\P{0}\P{1}\P{2}" LeaderStyle="AlwaysCorner" DefaultsOverride="true" Filter="EndConnectionsPipe" Fields="Attribute9 PIPELINE-REFERENCE CO-ORDS" />
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
@Ray_K ,
No, they have not been removed, they have never been integrated from the P3D LineGroup
Hartmut Eger
Senior Engineer
XING | LinkedIn
The pipeline-reference attribute is a container attribute, if you just click 'add' you can add another one of the PCF attributes. To add something inside the container you have to click the grey bar you see when you open the container, if you then click add you will see all pipelinegroup attributes:
If you want to add attributes outside of the container attribute, you will need to use the manual method.
