AutoCAD Plant 3D Forum
How to configure the continuation annotations using specific properties
4 REPLIES 4
Ray_K
135 Views, 4 Replies
I am trying to add specific P3Dlinegroup attribute to be included on isometrics continuation annotation but the P3D properties seems to be missing. I tested this on 2023, 24  and 25.
Refer to Autodesk Support website:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-configure-t...
4 REPLIES 4
h_eger
in reply to: Ray_K
@Ray_K ,
If you choose the manual option, it works very well. At least in P3D 2020, 2021, 2022, 2023, 2024 and 2025
<EndConnectionScheme Name="EndConnectionsPipe" AnnotationStyle="Standard" Format="FORTS. AUF\P{0}\P{1}\P{2}" LeaderStyle="AlwaysCorner" DefaultsOverride="true" Filter="EndConnectionsPipe" Fields="Attribute9 PIPELINE-REFERENCE CO-ORDS" />
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Ray_K
in reply to: Ray_K
@h_eger
Yes, manual option works.
I am just asking if the P3D Attribute was removed from the User Interface form.
h_eger
in reply to: Ray_K
@Ray_K ,
No, they have not been removed, they have never been integrated from the P3D LineGroup
Hartmut Eger
Senior Engineer
XING | LinkedIn
Michiel.Valcke
in reply to: Ray_K
The pipeline-reference attribute is a container attribute, if you just click 'add' you can add another one of the PCF attributes. To add something inside the container you have to click the grey bar you see when you open the container, if you then click add you will see all pipelinegroup attributes:
If you want to add attributes outside of the container attribute, you will need to use the manual method.
