I have created a T-piece which has a reduced branch connection. I know want the reduced T-Piece to insert correctly with the correct tag. The tag should look somthing like this: DN100xDN80. Which indicates that the main line is DN100 and the reduced branch is DN80.
Reducers in the program have also a similar tagging. But they only have 2 attachmentpoints.
How can I create a tag which only uses 1 size of the main line, and one size of the reduced branch.
Attached you can find the finished symbol and symbol in block editor. also the setting in the project setup.
Thanks for the help
