AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Plant 3D error
1 REPLY 1
Samir.gauswami
110 Views, 1 Reply
Plant 3D error
Plant 3D Error - The File Exists Hi, We are using Plant 3D 2021 and have recently come across the error - The File Exists when saving models. The implications of this are as follows: * unable to create new P3D models or drawings. The drawing will create but will not populate in the project manager * will run isometrics but these will not populate in the project manager * isometrics will not read and populate our titleblocks from our xcel spreadsheet but have done before this error occured. I have had a new PC built and P3D installed but am getting the same errors occur. The errors have recently started on other users PC's as well across the server. Any help would be appreciated. Thanks
1 REPLY 1
Here is another forum post of a user reporting a similar issue. The solution turned out to rebuild the windows profile.
https://forums.autodesk.com/t5/autocad-plant-3d-forum/plant3d-file-open-error-saying-quot-the-file-e...
