Guide to create a complete P&ID Project Template for Autocad Plant 3D
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi.
I have been posting many questions in this Forum about tool palettes backup, customizations, Plant3D settings, creation of templates, etc. to gain a broader understanding of how to set a good Plant3D environment for the creation of P&ID drawings and how to create Project Templates to facilitate future works. I'll now share some of the information I have so far and the difficulties I'm encountering. It's intended to serve as a guide to whoever want to create a project template for Plant 3D.
Initial Plan and goals to create a Plant3D Project Template:
- Get a clean Plant3D 2024 installation to identify all native Plant 3D P&ID objects.
- Create a new project and pick your standards through the new project Wizard window:
2.1 Symbology Standard: PIP was my choice.
2.2 Units: Metric System (selecting millimeters in it) - In your new project, customize it fully.
2.1 Customize the interface
2.2 Customize Tool Palettes Groups - Add, from Project Setup, all P&ID objects that might exist natively in Plant3D, but are not displayed in your Group Tool Palette (check the line, equipment, valve, instruments, fittings and non-engineering palette tabs for that).
- Create a New Drawing and customize a Drawing Template with TitleBlocks in it.
- Customize your Paper Layout ("Page Setup Manager...")
- Start the backup phase of the template creation by:
7.1 Exporting a PROFILE file from the Option menu
7.2 Exporting a "drawing template" file from the "SAVE AS..." menu
7.3 Exporting a " drawing standards" file from the "SAVE AS..." menu
7.4 Exporting a Project.XML file (simply enter your reference Plant3D project folder and copy the file named Project.XML from there to a safe location. When creating new projects, in the wizard window, point to it)
7.5 Export all "SUPPORT FILES". In plant3D 2024, the SUPPORT folder was found in
C:\Users\<user_name>\AppData\Roaming\Autodesk\Autodesk AutoCAD Plant 3D 2024\R24.3\enu\Support
7.6 From Tool Palettes, right click, 'customize palettes' option, and ten export .XTP files from each Pallete in the left side of the window (Modeling, Annotation, Civil, Electrical, Valves, Equipment, etc.) and also export .XPG "tool palette group" from the right side of this window.
7.7 Enter some random Plant3D folders and try to find everything that might be important in those folders to be backed up. Paths known so far are:
C:\AutoCAD Plant 3D 2024 Content
C:\ProgramData\Autodesk\Autodesk AutoCAD Plant 3D 2024\R24.3\enu
C:\Users\<user_name>\AppData\Local\Autodesk\Autodesk AutoCAD Plant 3D 2024\R24.3\enu
That's the most complete guide for creating a plant3D Project Template that people will find anywhere so far, in my opinion.
Whoever has anything to contribute to this list, please feel free to add extra steps or comments. Replicate the entire list in your reply with your suggested changes and/or comments. You are very welcome do to that!
While we keep updating those steps, I'll also ask for your help to troubleshoot any difficulties that others or I may encounter in the process.
The first issue, and very basic one, that I'll list here is:
- (SOLVED) Even before starting the backup process, after creating a new PIP, metric (mm), project, I created a drawing to test the native tool palettes, but surprisingly most of the P&ID objects in my tool palettes don't work! I tried the line object from the PIP tool palettes, and it worked. But when I tried the valves in the valves tab or a pump in the equipment tab, none of them worked and they all displayed the following warning:
How can that happen, when the tool palettes that I'm using is the PIP one, the project was created using the PIP standard, and the P&ID object I'm trying to use is a native object that comes with Plant3D, not a custom-made object?!?!
Thank you to all who decided to collaborate in the creation of this guide.
sd
