Getting error cannot connect part
pnair2YJ6G
pnair2YJ6G
Hi
I'm getting this error while creating a custom part. please find the attachment below.
please provide the solutions.
km4504
Not able to access the project setup dialog. What version are you using?
If my reply was helpful, please give a Kudos or click the Accept as Solution button below (or both).
pnair2YJ6G
2022 PLANT 3D
km4504
Sorry I am using 2024. Can't help on this one.
h_eger
@pnair2YJ6G ,
please also use the correct units for the block-based valves for a pipe spec in imperial units, the block-based components must also be created in imperial units, see your P3D drawing.
@km4504
it does not matter which version the P3D drawing has all P3D projects between 2018 and 2025 are upwards and downwards compatible.
I have edited this P3D drawing with P3D 2025.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
km4504
I was able to edit the drawing but I could not open Project Setup to check the settings.
h_eger
@km4504 ,
copy Drawing to Project...
and then into a metric project
Hartmut Eger
Senior Engineer
XING | LinkedIn
