- Mute
- Permalink
- Report
Hi
I'm getting this error while creating a custom part. please find the attachment below.
please provide the solutions.
Hi
Not able to access the project setup dialog. What version are you using?
please also use the correct units for the block-based valves for a pipe spec in imperial units, the block-based components must also be created in imperial units, see your P3D drawing.
it does not matter which version the P3D drawing has all P3D projects between 2018 and 2025 are upwards and downwards compatible.
I have edited this P3D drawing with P3D 2025.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
@km4504 ,
copy Drawing to Project...
and then into a metric project
Hartmut Eger
Senior Engineer
XING | LinkedIn
