AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Fatal error while creating new project
6 REPLIES 6
shadow931
413 Views, 6 Replies
The menu for creating a new project is empty and when I try to create one I get a fatal error. I had plant 3D 2017 which I replaced with 2018 and at that point the problem came out. I tried to reinstall i but with no luck. Any suggestions ?
6 REPLIES 6
ryan.bales
in reply to: shadow931
It looks like either your install is incomplete or you need to reinstall .NET and C++.
Ryan Bales
Fusion 360 Product Support
shadow931
in reply to: ryan.bales
Which .NET and C++ do I need, can I download them separately ? Because I don't want to reinstall it again.
ryan.bales
Use this for C++
How to remove and reinstall Microsoft Visual C++ Runtime Libraries
and this for .net
How to remove and reinstall the Microsoft .NET Framework
Ryan Bales
shadow931
Well I couldn't fix the problem by reinstalling the c++ and .net neither by doing a clean uninstall and reinstall. It even got worse so than when I installed the 2018 version after the clean uninstall it told me acad.exe file is missing so I could not even launch the program... So now I installed the 2017 version again which is working normally.
Slawomir_
Did you install 2018 with latest update? 2018.1.1
ryan.bales
When you mean clean uninstall did you wipe all Autodesk products from your computer?
Ryan Bales
