The menu for creating a new project is empty and when I try to create one I get a fatal error. I had plant 3D 2017 which I replaced with 2018 and at that point the problem came out. I tried to reinstall i but with no luck. Any suggestions ?
It looks like either your install is incomplete or you need to reinstall .NET and C++.
Which .NET and C++ do I need, can I download them separately ? Because I don't want to reinstall it again.
Use this for C++
How to remove and reinstall Microsoft Visual C++ Runtime Libraries
and this for .net
How to remove and reinstall the Microsoft .NET Framework
Use this for C++
and this for .net
Well I couldn't fix the problem by reinstalling the c++ and .net neither by doing a clean uninstall and reinstall. It even got worse so than when I installed the 2018 version after the clean uninstall it told me acad.exe file is missing so I could not even launch the program... So now I installed the 2017 version again which is working normally.
When you mean clean uninstall did you wipe all Autodesk products from your computer?
