Exclude Control Valves from instrument list of Data Manager reports
jeroen.bolwerk
jeroen.bolwerk
Trying to exclude the control valves from the instrument list of data manager, just as specified here:
https://knowledge.autodesk.com/support/autocad-plant-3d/learn-explore/caas/sfdcarticles/sfdcarticles...
However, nothing happens when I try this. Does someone know what I do wrong?
I put in this piece of code in InstrumentationIndex.xml
<LeftQuerySpecification xsi:type="PnPTableQuerySpecification">
<CorrelationName />
<Filter value="Description NOT LIKE 'CONTROL VALVE%'"/>
<TableQualifier />
<TableName>Instrumentation</TableName>
h_eger
Dear @jeroen.bolwerk ,
Please use XML correctly!
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
jeroen.bolwerk
Problem solved;
After downloading 'XML Notepad' it succeeded;
The following text needs to put in the xml file:
<Filter>Description NOT LIKE 'CONTROL VALVE%'</Filter>
Then the filter will work.
