Not that we've found, it's like Plant 3D and Revit don't live in the same world, let alone the same company. We've tried Plant 3d to revit and revit to plant 3d, it's all not good. On the plant 3d side you need to export from revit to .dwg and lose everything, same with plant 3d to revit, exporttoautocad. I'm thinking if there was a way to export the data from the plant 3d database and identify each item in the exported .dwg through revit and associate the data... maybe you could do something. Our "solution" is that in each other it's essentially a way to not clash, the data part is through navisworks -> datatools -> plant 3d sql server -> navisworks for a confirmation of data, it isn't great.
George
If my post offers a solution, please click "Accept as Solution"
