AutoCAD Plant 3D Forum
Equipment nozzle
7 REPLIES 7
Message 1 of 8
717 Views, 7 Replies
Equipment nozzle
why I can not see all flanges in nozzle editor which are in the NOZZLE catalog.acat?
thank in advance
7 REPLIES 7
Message 2 of 8
AndyDavisCadline
The Nozzle Editor does show all of the nozzles in the .acat file, the displayed list is filtered according to settings of size, unit, end type and pressure class.
What are you missing?
Andy
Andy Davis
Industry Specialist
Cadline Ltd.
Message 3 of 8
Hi Andy, thanks for the answer. The case is I tried all combinations (size, unit...) but B1 facing is not available in nozzle editor. But in NOZZLE catalog.acat it is.
Best regards,
Tamas
Message 4 of 8
李榕华|Ronghua.LI
在你修改完管嘴库之后,重启xx了吗?
Automatic translation:
After you modify the NOZZLE catalog.acat, restart Plant 3D?
李榕华
13489140049@qq.com
Message 5 of 8
h_eger
Hi Tamas,
can you please check whether the path to the content folder in your project is identical to the image of your spec folder in your post.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 6 of 8
in reply to: 李榕华|Ronghua.LI
Yes, I did.
Message 7 of 8
h_eger
to make sure you made the modification in your NozzleCatalog and Plant 3D was not open?
The data from the NozzelCatalog is only loaded once when Plant 3D is started.
If Plant 3D is open, changes in the NozzelCatalog are not applied immediately but only when Plant 3D is restarted.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 8 of 8
in reply to: h_eger
Dear Hartmut, thanks a lot.
Technology Administrators
AutoCAD Beta
