AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Ortho anno Elevation in Meter upto 3 decimal place
14 REPLIES 14
Message 1 of 15
2062 Views, 14 Replies
By useing the PLANTDEFINECALPROPERTIES command, I have created Ortho annotation of BOP in Meter but how can I fixed the BOP in Meter upto three decimal place.
14 REPLIES 14
Message 2 of 15
VinodBalasubramanian
Hi Bapan,
I believe Quentin has already answered you on this. Did you follow the same procedure as in this video,
https://chronicle.autodesk.com/Main/Details/991e51c8-2a32-40a4-a079-bec22bebb300
If so, can you send me your drawing for further review.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Message 3 of 15
in reply to: VinodBalasubramanian
Vinod,
My question is not to convert BOP El. from mm to Meter. Problem is to represent El. in Meter upto three decimal place.
Message 4 of 15
Have you tried under add annotation - unit target precision. It should provide you control on the decimal places you were looking to display. If not, you could try adding another attribute for unit under the BOP block and test.
Hope that helps.
Message 5 of 15
under add annotation - unit target precision is not available.
Message 6 of 15
help me
Message 7 of 15
Hi Bapan,
Apologies for the late reply. I was not well for few days. Please see the screenshot as its shown in the above video as well.
Message 8 of 15
Hi Vinod,
I have followed your above instruction but unable to control decimal place of Ortho anno Elevation in meter.
But the default BOP Class Property of Pipe Run Component, can control the decimal place that unit is in mm.
Please find the bellow link of test project for you checking the ortho annotation BOPINMETER and reply me.
http://a360.co/1hL6fUN
Message 9 of 15
Hi Bapan,
Sorry for the delay. Can you try to change the decimal places in the ortho-template via UNITS command and let me know whether it helps.
Message 10 of 15
Yes, I have changed the decimal places in the ortho template but no change in BOP annotation.
Message 11 of 15
hai sir,
If you clarify your query, please share how to achieve this. i have also same problem.
I need some querry also,
1. how to round up the elevation for example from EL 104.9999999 to EL105.000
2. how to generate flow arrow in ortho view
3. how to convert COP and FOF in mm into m
4. In piping ortho view show 15NB to 150NB double line but we need in ortho view for this sizes are single line only, how to generate.
P.Baskar
Message 12 of 15
The link to the video is broken. Can you help me to find it?
Message 13 of 15
rajendra.prajapat
@Anonymous change the Precision in cuurent drawing.please see below screencast for the same. it is working for me.
https://knowledge.autodesk.com/community/screencast/c47e5494-3405-46c3-8df8-d9882e1a286a
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Message 14 of 15
That is still millimetres
Message 15 of 15
I don't think that it is possible to do what you are trying to achieve without writing custom code or using a third party app.
Drawing Units affect only the values that are displayed by AutoCAD, they do not affect the actual raw data that is stored in the drawing.  Hence, changing the precision will work for values that are saved in the base drawing units (mm or inches for Plant drawings) and recognised by AutoCAD as known graphical object properties. The calculated properties manager is accessing the raw, un-formatted data value directly and AutoCAD does not know to apply the drawing units to this value.  Unfortunately, there is no way to format the value through the calculated properties manager.
The block attribute in the ortho annotation, reads the value of the Plant property into the attribute Tag field only and treats it as a string - it cannot be accessed in an expression and so cannot be formatted in the block.
I hope this helps.
Andy
Andy Davis
Industry Specialist
Cadline Ltd.
Technology Administrators
AutoCAD Beta
