Edit sline group feature missing
Hey!
Im working with Autocad P&ID and sometime I cant add annotation to my pipe lines. This is the same for all the pipe lines for the entire drawing. If I draw a new line the edit sline group function is back and I can add a annotation to it.
Do anyone of you guys know how to solve this problem? This problem has occurred more then one time and what I did then was that I removed the pipe lines and replaced them with new one.
 Grateful for quick answers!
BR
Tommy
Vicky.Wu
Hi Tommy,
This might be caused by Corrupted slines which are not part of a group.
You can try:
Enter for every AutoCAD P&ID project drawing the command AUDIT.
  • The errors will be noted with "Line Segment does not belong to any group" and  will be fixed afterwards.
Here is the link of AKN article which might be helpful for your case.
https://knowledge.autodesk.com/support/autocad-pid/troubleshooting/caas/sfdcarticles/sfdcarticles/Fo...
Vicky
Autodesk Plant Solutions
