Share view cube library between projects
David_Peek
David_Peek
I am wanting to share a set of view cubes between projects.  (copies)
I copy the view cube files into the \Orthos\Orthocube Library directory but they dont appear in the viewcube library command in Plant Ortho?
Is there a way to import the view cube library into plant 3D?
David
graham_lunn
Hi David,
Did you ever find an answer to this problem?
I find myself with the same issue.
