AutoCAD Plant 3D Forum
Welcome to Autodeskā€™s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Ductile Iron Pipe & Fittings as per ISO-2531 ?
3 REPLIES 3
Morpheus87
960 Views, 3 Replies
hello,
is the P3D Piping Catalogues for Ductile Iron Pipe & Fittings as per ISO-2531 available??
all that I could find is the AWWA standard witch in imperial units not metric like the ISO-2531
3 REPLIES 3
Did you check on the App Store for the catalog?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
I check the app store and I found DI pipes as per AWWA, AS/NZS & UK standards
I am seeking DI pipes & fitting as per ISO 2531 in metric
Hi, Did you find these Fittings?
