AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Slip on flange missing
7 REPLIES 7
Message 1 of 8
2563 Views, 7 Replies
hello,
In the "EN Piping Content Pack V1.1 EN" catalog the slip on flanges are stuck in the "stub end" row, so the dont appear in the tool palette in plant 3d. can this be fixed? or am i missing something?
thanks in advance
Adrian
7 REPLIES 7
Message 2 of 8
h_eger
Slip-on flanges are shown in the picture.
Stub-End
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 8
in reply to: h_eger
hi Hartmut,
thanks for you reply on this.
I'm not sure what your trying to tell me here?
yes we have seen that there are lapped flanges in the catalog, but as you know they are very different to slip-ons. (2 items v 1 item)
regards
adrian
Message 4 of 8
h_eger
hi adrian,
Slip-on flanges are not included in the catalog.
it involves the flanged to EN 1092-1 TYPE 1 Smooth flange for welding
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 5 of 8
in reply to: h_eger
hi  Hartmut,
Ok. I wonder why they would not include such a common item? very strange to us.
whats the easiest solution for this, do you know?
thanks again
Adrian.
Message 6 of 8
JUANCARLOSBLASCO4129
Hi
I think this is what you are looking for:
It's in "En pipes und Fitings EN.pcat"
They are named as welding neck with Design Std. 12.
What i'm going to do is to duplicate this item, check all dimensions, and change the name,
Regards
EDIT: Sorry, i made a mistake. This flange is lapped too (port 2)
Message 7 of 8
in reply to: JUANCARLOSBLASCO4129
Hi UANCARLOSBLASCO4129,
thanks for your reply,
ok cool, yes this is near enough to start with, so what i did was copied the flange and modified it to suit.
thanks again
Adrian
Message 8 of 8
greg.youngCXLLN
Hi, do you know if this is this still the case in 2020? version?
