I recently create a python custom script component (clamp).
When test it with "testacpscript" everything is fine but when I start using that clamp in my drawing the display seem broken, some kind of lacking resolution only on that component.
In the attachment, on the left of the picture is the one broken when insert from spec. On the right is the normal picture insert by using "testacpscript".
Can someone help me point out the problem, I very appreciated for your help.
I already tried:
1. GRAPHICSCONFIG hardware acceleration off
2. Change display solution (change Arc and circle smoothness from 1000 to 10)
Both way didn't work.
Solved by h_eger. Go to Solution.
If you work with Plant 3D 2022 I know this problem.
For me this problem is solved with P3D 2023.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
I'm using P3D 2021. Thanks for suggestion.
The problem disappear now, I didn't do anything. Weird.
