AutoCAD Plant 3D Forum
Display error with python custom script component
2 REPLIES 2
quan_hm
256 Views, 2 Replies
I recently create a python custom script component (clamp).
When test it with "testacpscript" everything is fine but when I start using that clamp in my drawing the display seem broken, some kind of lacking resolution only on that component.
In the attachment, on the left of the picture is the one broken when insert from spec. On the right is the normal picture insert by using "testacpscript".
Can someone help me point out the problem, I very appreciated for your help.
I already tried:
1. GRAPHICSCONFIG hardware acceleration off
2. Change display solution (change Arc and circle smoothness from 1000 to 10)
Both way didn't work.
Hoang Minh Quan - Piping design engineer
Autodesk Store for Python Catalog
Labels (1)
2 REPLIES 2
h_eger
in reply to: quan_hm
If you work with Plant 3D 2022 I know this problem.
For me this problem is solved with P3D 2023.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
quan_hm
I'm using P3D 2021. Thanks for suggestion.
The problem disappear now, I didn't do anything. Weird.
