Disabling Bolt lengths
Is there away to disable bolt length in plant 3d?
Example:
In the size column in the iso, I would like to have only M12 and not M12x50.
Is that possible?
mmcmorris
Sadly I don't think there is a way to do this.  The closest work around I can think of is to remove the ND field for fasteners in the table and add M12 to the long description.  Issue is it will affect everything else in the fasteners class such as gaskets.  Sorry 😞
Slukerin
u can open data manager find bolt and nuts in left column and manualy set m12 in any empty column for all positions ur need.. then u need to change table setup (screenshot) and add this column. this is not a good way to solve ur problem. but it work)
Please can you resend the screen
shots but in English??
Slukerin
sorry but i can't. i have only russian version of plant3d. i hope u can find all this positions (just try to look intently on the icons on the screenshots.
