Custom pipe support made from python
jeremypatterson
jeremypatterson
So I'm making custom pipe supports for the company I work for and the problem I'm having is that I got the support made and it test fine, until I add it to a catalog.  What is happing I can import the support, in order to make changes in properties manger I have to copy the support for it to work else it removes the model. Is there a way to fix this?
here the code
quan_hm
Your code have an issue:
    s.setPoint((0.0,0.0,0.0), (0.0,0.0,0.0))
The direction should not be set to 0,0,0. It should be set in direction of the pipe. So it should be
    s.setPoint((0.0,0.0,0.0), (1.0,0.0,0.0))
 if the pipe is in X direction comapre to original direction of the support.
And the script name must be the same as the function name so "PBS142.py"
Hoang Minh Quan - Piping design engineer
Autodesk Store for Python Catalog
jeremypatterson
Thank you for the help, that fixed it.
quan_hm
Great, you're welcome. Maybe it's time to mark it as answer :))
