How do you add parts to the custom imperial cat and spec?.
Ideally I'd like to create my own cat and spec with parts that can be adjusted dimensionaly in the modeling window much like the out of the box custom parts spec behaves.
I attempted to copy the out of box custom cat and spec, rename it and move forward, unfortunately to no avail...any advice on this subject is appreciated.
Thank you
David,
Setting the component designation to "Custom" does not appear to function in our in-house built specs, populated by our in-house built cats.
We enter "Custom" but when going to the model space the part geometry in the properties tab remains grayed out therefore not allowing us to manipulate the part.
This component designation "Custom" only appears to function when using the out of box custom spec and catalog, is this a correct statement or are we missing something?.
It appears that entering the text "Custom" into the component designation field IS case sensitive, caps "CUSTOM" fails to register, lower case with a cap C, "Custom" works well.
Hi this is my very first Post on Autodesk forum feeling great.
ok so I tell you that what ever we are modelling in plant 3D after fetching them form Custom Part or Specs, are first created by Python script which we compile by Plant 3d "plantregistercustomscripts".
You can refer below given address.:-
http://adndevblog.typepad.com/autocad/2016/01/custom-python-scripts-for-autocad-plant-3d-part-5.html
so you need to have knowldge of Python for creating new parametric shapes.
Step 1> Python Script (which contain Geomtry related code, Port information, Category etc.)
Step 2> then place that script in
Step 3> after compilation it will start appear in its group category like fitting, Valve, as defined in script in both "Spec Editor" and in "Coustom Part" dialog box .
Step 4> than you can add your spec as well.
