Hi, I'm Oka.
I need help with this problem.
What I did:
Import STEP file (Attachment 2) --> Create Block --> Plantpartconvert and add 2 connection points --> Add custom part and define the connection [Bottom: 3/4" THDM; Outlet: 1" THDF]
The Problem:
I connect a 1" Plug, Hex Head, THDM (SS150) [Recieved from the catalog] to the PSV's 1" THDF outlet.
They are connected (The water symbol is gone) but not fully inserted (Attachment 1).
***I tried to repeat what I did with variations on the 1" THDF outlet during Plantpartconvert [Change the location point or the direction], but it still gives the same result.
Ah, I have already solved the problem.
I just need to save and re-open Plant 3D every time I want to adjust the Plantpartconvert location point.
